By passing bravo shift bracket plate. >
Old 03-22-2026 | 09:00 AM
Default By passing bravo shift bracket plate.
Is there a kit or modified bracket to attached the Bravo 1 shift cable from TSK to go to 33c style control at console end.
I would like to go from tsk cables straight to the shift head.
thanks.
tristan247 is offline
Old 03-23-2026 | 10:45 AM
Bill 3's Avatar
If I am thinking right, you basically need to go from a threaded rod to a ring terminal?
Something like this?
https://www.bow.com/product/seastar-...0-seri-317413/
Bill 3 is offline
Old 03-23-2026 | 06:01 PM
why? the bracket changes the ratio so the shift lever moves the set distance and it also makes it easier to move. by removing it you would need both the transom cable and the shifter cable to be mounted to something and then connect them but you would make the throw of the shifter shorter and harder to move.
compedgemarine is offline
Old 03-24-2026 | 01:16 AM
I have re rigged from TRS and gearbox to Bravo 1 XR. So have no shift plates. And my throttles and shift on the boat take 33c style. So I need 2x shift plates to go on the end of the TSK cable. And change to 33c to go to the console.
