-   -   Bad fuel end of last season, what to do next? (https://www.offshoreonly.com/forums/general-q/387731-bad-fuel-end-last-season-what-do-next.html)
92cobalt243 04-02-2026 06:38 PM
Originally Posted by ICDEDPPL (Post 4945406)
You`re lucky you didn`t blow an engine or 2. I did fter getting some terrible gas.. I prefer ethanol, keep the AIT down , as long as you go thru it in a few weeks it`s not an issue.
You got bad gas or water in your gas from an external source, that`s not phase seperation. That takes a long time.I did some testing on that .
https://cimg9.ibsrv.net/gimg/www.off...ad5bce1b4f.jpg
https://cimg0.ibsrv.net/gimg/www.off...0540f0fd53.jpg
https://cimg1.ibsrv.net/gimg/www.off...66a9c3fe3f.jpg
Ouch!! The boat is 34 years old and I’d still prefer to keep using the 91 non-ethanol…my wife and I just retired so the boat is going in the slip at least 1 more year (paid for now)…I’m in a calm part of the marina with nose towards the lake and our typical weather. The vent is about 18” above the water line. Thinking about the AVD Fuel Guard (AVD-3) inline vent moisture separator for added protection. Thanks for your input 👍
496blower 04-02-2026 08:13 PM
I always have the vent line with a loop in it above the vent through hull makes it harder for water to get into tank, if you are replacing the vent hose get it a couple feet longer and use a zap strap to put a loop in it, couldn’t hurt
92cobalt243 04-02-2026 09:15 PM
Thanks…I’m replacing it anyway and it already has the loop higher than the through wall termination. I’ll replicate it 🤙
Tartilla 04-03-2026 02:38 PM
Maybe you already had water in your tank...and the ethanol gas just mixed with it...and serarated?
One of the benefits of 10%ethanol gas...is it keeps water out of the system.
seafordguy 04-03-2026 02:41 PM
I’d pump all fuel out if you don’t know what’s in there or question it in any way. GET a 55 gallon barrel on line and then give it away. Lots of people on FB will take it for some god forsaken reason!!
if you’re worried about the hoses, AN line is cheap and easy, but if the fuel looks like THAT it’s not from bad lines it’s bad fuel. Throw a couple new filters on the boat and change them often. I’d drain carb bowls as well, which is also quick and easy to do.
496blower 04-04-2026 10:06 AM
I don’t know if you have the space but I use the racor filters that have a drain on the bottom, I do use the ones with the clear bottom so you can see if there is water in the filter( technically not allowed in engine compartments they use a metal one with a drain)
