Manifold dump + dry exhaust? >
Old 04-23-2026 | 03:19 PM
Default Manifold dump + dry exhaust?
A bit confused here, why would this be set up to have both dry to the tips (water jacketed) risers and manifold dumps? Transom pickup + crossover, possibly for water pressure but I don't think the risers would be a restriction. Looking to save 2 holes in the hull
CheckmateScarab is offline
Old 04-23-2026 | 03:28 PM
Not only that...but the preferrential flow would be to the transom outlet. The feed to the manifold is right under the transom outlet, and less restriction than riser flow.
Unless there is a restrictor in the transom outlet system..and setup as a pressure reducer as you suggested.
Tartilla is offline
Old 04-23-2026 | 04:11 PM
SB
Hard to get in someone’s head of why….
Looks like this engine has a dominator carburetor. If so, this usually means large cid and big cam. Maybe they are attempting to reduce water thru the risers for this reason…..but not really a good way to do it. Maybe this boat previously had dry exhaust ?????and confused the person who did this ???
Lots of maybe’s.
Let’s go with what is known hopefully. Can you give us engine details ?
side note: looks like all the aluminum parts have some corrosion. This boat see salt water and/or salty air ?
SB is offline
Old 04-27-2026 | 01:32 PM
Lots of maybe’s.
Great observations - was run in salt water yes (flushed after ever use) and 565cu 720hp. I am also guessing the boat had a dry exhaust previously as the manifolds might be choking the engine at this size, but I've also heard it's negligible. I am thinking of removing the manifold dumps are running everything to the risers
