outdrive finish protection >
Old 05-13-2026 | 11:58 AM
26sonic's Avatar
Default outdrive finish protection
any suggestions on keeping a outdrive finish like new when leaving in fresh water for extended periods of time ? have all the necessary zincs . any products to apply ?
26sonic is offline
Old 05-14-2026 | 07:05 AM
Prep work always seems to be the biggest factor with outdrives. I’ve seen a lot of people have decent results when they completely strip the corrosion, use a good self-etching or zinc chromate primer, and then topcoat with Merc Phantom Black or a quality 2-part marine paint. Once the finish gets chipped, especially in salt water, it feels like it’s a constant maintenance battle. Keeping the anodes in good shape and watching for stray current issues probably matters just as much as the paint itself.
williamapston is offline
Old 05-14-2026 | 05:50 PM
A drive that lives in salt water in a marina with stray power...vs a trailered machine in the salt and washed/run with fresh water after every exposure.
Sand and feather the chipped areas. Reprime with zinc chromate..and proper paint.
Tartilla is offline
Old 05-14-2026 | 06:36 PM
YES, put your boat on a lift and keep it OUT of the water. If you plan on keeping a boat for a while it will pay for itself over a short time and keep the overall maintenance to a minimum.
GLENAMY 242SS is offline
