cam selection help >
cam selection help
cam selection help
Old 12-22-2002 | 04:38 PM
mxz800's Avatar
Default cam selection help
ok, im in the process of rebuilding a friends 454/330. so far the bottom end is staying stock rering/rebearing. rpm air gap inatake,merlin steel heads(269 runners 119 ccs) roller rockers. the boat is a chapparell 2550 about 5k if i had to guess, and using stock exhaust with thru hulls. was thinking about the torker plus but says 2500 to 6500 rpm range. i am trying to get a cam that can be ordered thru summit not a custom grind. this is a heavy boat that is used for enjoyment not an all out racer
thanx Rob
mxz800 is offline
Old 12-22-2002 | 05:12 PM
Default Here is a good one!!
Straight out of Summit. PN SUM-K1301 218/228 duration at .050" on a 114 ls with .500" lift.
WETTE VETTE is offline
Old 12-22-2002 | 05:40 PM
CRN-133802 222/234, .529/.525, 114 lob sep $150
CRN-134242 226/236, .534/.553, 112 lob sep $160
Both these are cam kits that include lifters, lube and lock plate. I have the second one in my 454mag and its got a lopey idle, but still idles at 750rpms in gear with 12* initial timing. Not sure about reversion with it and stock exhaust. I have Imcos.
Griff is offline
prostockcat
5
09-26-2008 09:35 AM
MattBMiller
6
12-08-2006 08:43 AM
OldEliminator
7
06-03-2005 10:04 AM
Andy
7
04-19-2003 03:16 AM
TomR
3
09-06-2002 09:46 AM
