-   -   Bravo XZ drain plug washers (or not) (https://www.offshoreonly.com/forums/general-q/39705-bravo-xz-drain-plug-washers-not.html)
envision 12-27-2002 10:24 AM
I am refilling my Bravo XZ but there appears to be no washers on either the top or bottom drain plugs. I didn't see any come off.
There looks like a copperish colored band but it is very thin.
I checked on the BAM site and they show that the top screw definitely has a washer but I still am unsure about the bottom screw.
Anybody know for sure?
Thanks!
Turbojack 12-27-2002 11:29 AM
Mine has O-rings. Top & Bottom. I just drained oil this last weekend & checked the o-rings to make sure they were still OK
Dock Holiday 12-27-2002 12:10 PM
Hope this helps. I just changed the oil on my XZ's a couple of weeks ago. This is the first time I did it myself.
All I had was the "copperish colored band" also. By accident I left the one off on the starboard drive on the lower drain plug. The next morning I had an ounce of oil on the floor.
Discovered what had happened, put the washer on and no problems.
Good luck
envision 12-28-2002 05:47 PM
Thanks guys.
I found that the copper washer does comes out when you least want it too like after the drive is full.
All back to gether now.
