Question for GeoGraphics INC >
Old 12-30-2002 | 04:32 PM
Default Question for GeoGraphics INC
GeoGraphics INC,
As a follow up to your response to buffing Imrom.
What pad & compound do you suggest for solid white gel coat? Not damaged but just to maximize the shine.
Will you have a booth at the Miami Boat Show?
Thanks in advance.
Mark
GETTINBYE is offline
Old 12-31-2002 | 12:07 PM
GeoGraphics INC
Gettin'bye If you are buffing gelcoat the best stuff is Aquabuff 2000 made by Hawkeye industries and a 3M superbuff compounding pad it will work wonders on gel hope that helps ps we are painting a 38 & 44 MTI for the showas we speak If you have any other questions call me at 888-382-9992 Mike Nicholson
Old 12-31-2002 | 01:15 PM
GeoGraphics INC
Thank you for the response. Re: Miami - I am assuming that this means that you will be there. That being the case I will try and look you up at some point while we are there.
Mark
Old 01-01-2003 | 07:41 AM
cig1988's Avatar
G.G.INC.
What would be the best way to remove/fill deep scratches in gel coat?
cig1988 is offline
Old 01-02-2003 | 08:14 AM
GeoGraphics INC
Cig 1988 You have 2 options availible to you fill them with a matching gelcoat or fill with a good filler (polyesther or epoxy) and blend in with paint
thedonz
04-13-2006 08:02 AM
GeoGraphics
01-22-2006 10:01 AM
josh76
07-14-2004 04:14 PM
Luv-N-It
06-20-2003 11:07 AM
Dock Holiday
Baja
8
07-04-2002 01:48 AM
