502 Generation Differences >
Old 01-07-2003 | 03:30 PM
outlawinil's Avatar
Default 502 Generation Differences
Hey guys I need some info on 502's. I am looking to repower my boat and have found Gen IV carbed 502's and Gen V EFI 502's. I thought all EFI's were Gen VI. These motors have almost the same hours on them and i am wanting to do the rebuilding at a machine shop that I trust. They will need to be gone through and checked. I was planning on using some hi-po parts which is a whole nother topic. Same money for both which is the better buy? Or do Gen IV and V motors have a weakness and therefore should I be looking at Gen VI's?
outlawinil is offline
Old 01-07-2003 | 09:18 PM
Vinny P's Avatar
I hate the winter!!
OK, I will give this one a shot. I hope I don't leave too much out. From what I remember, Chevrolet introduced the Gen V in 1991. Some of the differences between Gen V and Mark IV are as follows:
The water passage holes on the deck of a Gen V and Mark IV are different. You can't swap heads from a Mark iV to Gen V.
The Gen V has a 1 piece rear main seal vs. a 2 piece in the Mark IV. This means the cranks are different.
Gen V has the main oil supply passage up by the camshaft where as a Mark IV has it down by the oil pan rail.
Gen V has no provision for mounting a mechanical fuel pump.
The main bearing caps are longer in a Gen V block.
In 1996 the Gen VI was introduced. These motors came with roller lifters, the lifter bores were redesigned. I believe they were made taller as well. Other than the lifter bores, the Gen V and Gen VI are pretty much the same blocks.
As far as 1 block being better than the other. I couldn't say that I prefer 1 over the other. It is a matter of what you want to build and what is available.
I hope I didn't forget to mention anything too important. good luck in your re-power.
Vinny P is offline
blckkat
Sea Ray
0
02-12-2008 11:31 AM
bmanafort
02-27-2006 11:55 AM
G Man
Banana Boat
7
10-01-2005 07:52 PM
JUSTONCE
02-27-2004 02:49 PM
