out board charging system >
Old 01-09-2003 | 03:30 PM
pro design
Default out board charging system
what do you do when someone wants 2000 watts of power in a 37' intrepid with tripple 250 outboards. how do you supply enough current with stock charging? help.
d.
Old 01-09-2003 | 08:31 PM
mcollinstn's Avatar
Average 250 horse OB has a 35amp alternator. This means that ech alternator can put out (35a x 13v) 450watts. 3 motors makes (450w x 3) 1,350 watts.
Using a 3-input isolator will allow you to combine the outputs.
You're going to need 170 amps of alternator output to get what you're after.
NOW, are you sure you need 2000watts CONTINUOUS? If not, then your 3 35a alternators should keep your batts charged.
Each group 27 battery gives around 90 amp-hours of juice. If you are running 2000 watts off the battery, and you have all 3 motors running 3500 rpm or so, then you are losing around 850 watts to the load. At that pace, you could be discharging to the tune of 70 amps. This means that you can run like that for a little over an hour before you get into undervoltage...
1 grp 27 - 1.25 hours
2 grp 27s - 2.6 hours
you get the idea...
tell us what the intended use is - might be interesting...
mcollinstn is offline
Old 01-09-2003 | 09:08 PM
Ted G's Avatar
It is unlikely that the 2000 watt stereo will run at more than 200-300 watts at any time and certainly not for more that one or two songs before everyone's ears start to bleed I have played parties for 200-300 people and never used more than 150 watts per channel on the meters. I think that with a stereo system of that nature a couple of dedicated gel cell deep cycles might be nice, but worrying about a constant 2000 watt load is probably not necessary.
www.cbpba.com
Ted G is offline
Old 01-10-2003 | 11:53 PM
mcollinstn's Avatar
oh, is this a stereo we are trying to power here?
David Stotz
Drives and Lower Units
6
09-18-2007 05:05 AM
slawson2000
4
05-13-2006 04:42 PM
cloudmaster_321
14
05-27-2005 10:58 PM
tmthunder
2
08-27-2004 09:48 PM
38cigmike
1
08-03-2004 01:05 PM
