oil drain/fill plug , alpha/bravo , are they the same???? >
Old 01-13-2003 | 08:39 PM
Hot Boat's Avatar
Team Dysfunctional
Default oil drain/fill plug , alpha/bravo , are they the same????
Is the top oil fill/ drain plug on a alpha 1 the same as a bravo???
I am looking to get a oil reserve canister that taps into that location , but it says its for a alpha . is there a difference ????
Hot Boat is offline
Old 01-13-2003 | 10:37 PM
SSComp's Avatar
I do not think you are talking about the lower oil/drain plug (67892a1) which believe it or not is the same on Bravos and Alphas. Even though there in different places. Alphas has it in the gear housing the Bravo on the bearing carrier (behind the prop).
The Alpha and the bravo have a different upper over flow plug:
Bravo: 67892a1
Alpha: 79953q2
I believe the thread is the same but go to a parts dealer and check!!!
SSComp is offline
Old 01-14-2003 | 07:57 AM
Hot Boat's Avatar
Team Dysfunctional
Yep I'm talking about the over flow plug. If the threads are the same then I am in business. I will have to check.
Hot Boat is offline
East Coast B
7
03-24-2007 11:06 AM
cbgenrl
3
04-18-2006 09:12 PM
ga1990
7
05-17-2005 01:50 PM
Kokopelli
8
05-24-2004 04:39 PM
cardshark 388
18
02-05-2002 04:48 PM
