another whipple question >
Old 01-21-2003 | 05:58 PM
Default another whipple question
How does cam timing affect power with the Whipple system? In other words, using an HP500 carbureted kit on a 540 ci engine(stock cast iron heads, 7.5:1 compression) , would it be better to stay with the stock HP500 cam timing or would using a blower specific cam make substantial gains in power? Does the blower move any air at idle speed to help smoth out a radical cam? Thanks for the advise.
shockwaveharry is offline
Old 01-22-2003 | 12:32 PM
Question
no one has any input?
Old 01-22-2003 | 12:41 PM
Whipple Charged's Avatar
Harry,
There is a lot to be gained in camshaft design on the 500HP Carb engine, stock cam is certainly nothing special. If your going to a 540, the carb should be changed to a minimum 1050cfm. So if your building a 540 carb engine, you should change the camshaft to a much more aggressive cam design for the SC. The screw compressor will idle far better than any roots, so you can go very aggressive with the cam.
Dustin
Whipple Charged is offline
Old 01-22-2003 | 12:47 PM
blown1500
Hello shockwaveharry,
I have done some work with this set up and can tell you a cam is a big plus. pm for details
Old 01-22-2003 | 02:24 PM
Thanks for the response.
Old 01-24-2003 | 08:13 AM
Check your messages
liquid asset
11
02-25-2007 09:20 PM
Pure Energy
0
10-29-2005 04:27 PM
boat4life
0
04-10-2004 08:52 PM
Von Bongo
1
03-23-2003 12:01 AM
Breathe Later
4
03-15-2002 07:42 PM
