-   -   Polishing satin finish stainless steel (https://www.offshoreonly.com/forums/general-q/41603-polishing-satin-finish-stainless-steel.html)
liquid asset 01-21-2003 08:12 PM
Polishing satin finish s.s. headers, is it possible, any ideas????
paradigm shift 01-21-2003 08:22 PM
Possible. LOTS of WORK. Have it done :D
HOUSTONPROP 01-21-2003 08:51 PM
all it takes is time and money/oh also the know how part,I think it would be better to have them chromed? easier and cheaper and it would look perfect.just my thoughts.Darin
Griff 01-21-2003 09:20 PM
1 Attachment(s)
I guess it depends on how polished you want them. I just got a set of CMI Platinum Series headers with the polished upper and satin lower. After about 4 hours per header using only Mothers mag wheel polish, the lowers are looking pretty good. It is by no means as good as a factory polish job, but unless you look at it up close, you can't hardly tell that they are'nt fully polished.
liquid asset 01-21-2003 09:39 PM
those look like the same header, but mine are all a machine or satin look
Griff 01-21-2003 11:13 PM
They are CMI Unitops. Fully polished from the weld where the 4 runners go into the riser. I probably could have gotten the lowers fully polished out if I had started with some real fine emery cloth. They look pretty good though and the extra work wasn't worth it to me.
Cord 01-22-2003 08:25 AM
Grainger carries 3m deburring wheels. You'll want the medium grit. Get a couple of different sizes/shapes and mount them in a die grinder. Go nuts. These wheels will leave a light satin finish that actually is rather attractive. You can now go to the emery on a spiral wheel. Usually the emery leaves a pretty good shine. Finish off with the stainless compund and you're done!
Big E 01-22-2003 11:59 AM
Hey Griff - those look nice. I have a standard stock prop on a 29 Outlaw with a dull, I guess satin finish. My old boat a 252 Islander had a stock prop on it but it was very polished. Can I get that look out of my prop for the 29 Outlaw by doing what you just did? Or are we getting into labbing to get that kind of look?
HOUSTONPROP 01-22-2003 12:17 PM
poling prop only
YOU DONT HAVE TO HAVE THE PROP LABBED,it would be consired a basic clean up and polish /will be gald to help /just give me a call.Darin M;)
HOUSTONPROP 01-22-2003 12:20 PM
good job! they look great.
