Aerodynamics on cats?
There was a thread a few months back regarding aerodynamic lift on cats, ground effect, lift, angle of attack, etc.
Anyway, I was wondering how much additional lift you could generate with a wing at the bow between the sponsons. It seems to me that a front wing and tunnel tab extension could be a good way to generate a little more lift for a heavy cat (ie. chris cat).
Specs: 4' wide, 1' long, variable angle, 100mph top speed.
Gary
Gary
Yes, but they are really set up to plant the nose suddenly, and also "spoil" the airflow over the rest of the hull(deck) to kill off the lift from the main hull body, which you can do by giving a quick kick to the wing and letting it's wake dump over the deck.
Lift varies as the square of speed, so 200 mph is 4 times the force. Still not much for an 8000# offshore, but quite a bit for a 1500# hydro. If you go to multi-element sections like the top fuel cars do you can get the CL part of the equation up to about 2.5, but at a lot more drag.
-Greg
-Greg
