502 short block weight? >
Old 02-02-2003 | 03:20 PM
obnoxus's Avatar
Charter Member #1171
Default 502 short block weight?
Before I make a mistake,,, does anyone know the weight of a 502 with crank rods and piston in it,,,, I pulled the heads off in a cradle stand I have, but want to spin it to do the lower end easy, just dont want to assume my rotate stand will hold it,,, I had a full dress small block on it, so I wouls ASSUME it will hold it but you know how that goes !!!!!!!!!
I want to live in a world where a chicken can cross the road and not have its motives questioned.
obnoxus is offline
Old 02-02-2003 | 05:10 PM
Scarab28's Avatar
Here's a guesstimate - BBC complete weighs 800+ lbs. Each head weighs 63 lbs. That leaves you with 600+ lbs.
Scarab28 is offline
Old 02-02-2003 | 07:25 PM
mcollinstn's Avatar
Scarab, you gotta be wrong. The last set of heads I hauled out of the bottom of a cabin cruiser and carried up two flights of narrow stairs HAD to weigh 350 pounds each. That means that the shortblock weighs....
around a hundred pounds.
Anyhow, a BBC minus heads definitely weighs less than a dressed SBC.
mcollinstn is offline
Old 02-02-2003 | 10:45 PM
paradigm shift's Avatar
The last set of heads I hauled out of the bottom of a cabin cruiser and carried up two flights of narrow stairs HAD to weigh 350 pounds each. [/B][/QUOTE]
paradigm shift is offline
Rockfish71
4
05-29-2008 01:39 PM
BadDog
2
05-04-2005 07:53 AM
otis311
13
05-02-2004 09:29 PM
ScottB
02-18-2004 08:19 AM
otis311
4
07-27-2003 08:30 PM
