Removing Old Name from Stern >
Old 02-13-2003 | 06:06 PM
cheitman
If there were no such thing as bad luck, I'd have no luck so I left the name on my boat alone! "PROBABLE CAUSE" people always ask if I'm an attorney.
Old 02-13-2003 | 11:42 PM
jcboats
Default removing old name
i have removed 3 names from boats over the years and do not
beleive it brings "bad luck".
there is a product that i have used every time called jabsco paint remover for fiberglass surfaces. it is especially formulated to use on fiberglass surfaces.
after use wash with plain water and a mild soap, then use a light grit compound to take off the outline of the old name and buff entire transom.
this stuff is top notch!!!
jc boats
Old 02-14-2003 | 12:12 PM
GLH's Avatar
GLH
Thanks JC and all keep sugestions coming the shrinkwrap is'nt coming off for another month or so!
GLH is offline
Old 02-14-2003 | 12:17 PM
Baja Bopp
Just spray it on and the letters will run right off. Just watch it and maybe rub it a little with a towel. Wash it off with water.
I was rubbing off a couple letters/hour with acetone.
BTW, dont use Easy Off on a painted boat, duh!
Gary
Gary Anderson is offline
bmergner
16
03-09-2025 08:58 PM
mhifko
10-02-2007 07:27 PM
thedonz
12-12-2003 04:03 PM
Whassup
05-27-2002 07:24 PM
