engine unstarted for 16 monthes? >
Old 02-16-2003 | 06:40 AM
cig1988's Avatar
I would be concerned about the valve springs. Every 3 weeks I usually sping the engine a half turn. I have a problem with my big block jet boat a few years back. The boat sat for a year without doing this. Needless to say a valve hung up and kissed the top of the piston. needless to say the rest is history.
cig1988 is offline
Old 02-16-2003 | 07:20 AM
cougarman's Avatar
Default OIL ?
I would pull the distributor as easy as they are to time.
I had one down for a few years and had the engines on
stands. I pulled the distributors and bought the priming
tool for a drill and primed them once a month until she hit
the water again.
Maybe I went over board, but with your natural
heating and cooling cycles heated garage or not metal
sweats. Humidity changes corrosion is always a
chance. So if you do pull the lanyard your still dry
cranking possible rust pits.
I guess you need to decide if an extra hour or two
is worth the investment your spending to do it right.
Good Luck
I hope every thing works in your favor
Cougarman
cougarman is offline
Old 02-17-2003 | 10:48 AM
BAJA WILL's Avatar
Registered User
Seems like allot of work to make sure it runs??? I would, put some new gas in it and fire it up. Maybe a few turns with the kill switch out but thats it. My experience, I know most engine wear is done when starting but, hell most people blow the motor up way before they actually wear out.
My 2 cents
Will
BAJA WILL is offline
Clay Washington
01-16-2006 02:27 PM
JGB
40
02-16-2005 10:26 AM
Cigaretteman
3
11-13-2002 06:08 AM
