502 mag specs help >
502 mag specs help
502 mag specs help
Old 02-14-2003 | 08:15 AM
Default 502 mag specs help
Can any one tell me the depth in the hole for the pistons and volume of 1991 502 mag. motor. I am trying to figure compression on a head upgrade. thanks
Bad to the bone is offline
Old 02-14-2003 | 09:53 AM
Default 502 mag head upgrade
Thanks for the info. to be more spefic i am looking at some
Brodix bb 2 plus heads with 100cc chambers on my 502 mags
i have upgraded everything except the heads need compression
seems like a good fix. What do you think would be the final
compression. thanks again
Old 02-14-2003 | 10:46 AM
ursus
I deleted my other post casue the math was incorrect, sorry, hadn't had enuff coffee yet this is the correct way to do it
Just work backwards, stock compresion ratio is 8.75 to 1
The swept volume of one piston is
502.2ci/8 = 62.8ci or 1029.1 cc
so to find the combustion chamber volume
8.75 = (1029.1 cc +Chamvol) / Chamvol
8.75 * Chamvol - Cham vol = 1029.1
7.75 * Chamvol = 1029.1
Chamvol = 1029/7.75
Chamvol = 132.8cc
Since the stock heads are 119cc and the new heads are 100cc the new chamber vol will be
132.8 cc - 119cc + 100cc = 113.8cc
and so the new compression ratio will be
(1029.1cc + 113.8cc ) /113.8cc = 10.04 : 1
Old 02-14-2003 | 11:25 AM
thanks alot for your help most appreciated. greg
PROMAN
3
06-27-2005 03:29 PM
Smitty
10
03-11-2005 07:42 AM
homan
2
03-07-2004 09:48 PM
Mintish Panther
Scarab
5
12-22-2003 05:23 PM
Aces & Eights
1
07-23-2002 02:08 PM
