compression/ leakdown test w/ engine torn appart? >
Old 03-04-2003 | 07:07 PM
Default compression/ leakdown test w/ engine torn appart?
I'v got my engines tore down to replace cams, can I do a compression test with the engine torn appart or does it have to be assembled and sealed?
THRILLSEEKER is offline
Old 03-04-2003 | 07:20 PM
Turbojack's Avatar
When you say torn apart do you mean heads are off? If you heads are still one you can still do a leakdown test. Better of the 2 tests. A compression test needs the cam installed to do correctly.
Turbojack is offline
Old 03-04-2003 | 07:45 PM
heads are on, I just want to check and see if I need to replace rings or not while the engines are out.
Old 03-04-2003 | 08:12 PM
Vinny P's Avatar
I hate the winter!!
As long as the heads are on, it is no problem to run a leakdown test.
Vinny P is offline
Old 03-04-2003 | 08:31 PM
check454mag, I am assuming that rocker arms have to be installed and properly adjusted??????
Old 03-04-2003 | 09:21 PM
obnoxus's Avatar
Charter Member #1171
nope,,, actually it is easier with them off,,, dont have to worry about getting the cam in the right spot to insure fully closed valve
I want to live in a world where a chicken can cross the road and not have its motives questioned.
obnoxus is offline
Old 03-05-2003 | 05:47 AM
Turbojack's Avatar
To do a leakdown test you need to have both valves closed. You screw the leakdown tester in the sparkplug hole. The tester has 2 gauges on it. You have a pressure regulator & adjust the pressure on it. I set mine at 100lbs. You then look at the second gauge. If it shows 85 then you have 15% leakage. The older the motor gets or if it has a problem the number will get lower. Liisten to the intake or exhaust. If you feel/hear air then the valve is not seating & that is where some of the leakage is going.
Old 03-05-2003 | 07:28 PM
Vinny P's Avatar
I hate the winter!!
I agree with TurboJack. But, I will add making sure the piston is on T.D.C. for the cylinder you are checking.
Vinny P is offline
Old 03-05-2003 | 08:06 PM
Turbojack's Avatar
checkmate- I was told the same but I thought it was to make sure the valves would stay shut. Hopefully someone that may know another reason will chime in.
Old 03-06-2003 | 08:53 AM
blown1500
Hello, Guys,
The rings seal best at TDC when in good condition. The seal at the bottom of the bore is not usually as good. Also, when the pressure is applied, unless you are at top center or bottom center, the piston will try to go to bottom and could spin unexpectedly.
ak
6
10-19-2008 12:33 PM
articfriends
11
02-16-2007 06:22 PM
onesickpantera
6
10-09-2006 08:58 PM
Toffen
1
12-04-2003 07:58 PM
