Cam ?
Old 03-31-2003 | 08:07 AM
engreps's Avatar
Question Cam ?
502 Bow Tie with Merlin heads. Blower
I have been looking at the Crane HR-299-2S-12IG.
Hydraulic Roller
In/ex232242 duration 296/304 lobe separation 112 grass lift .610/.632
I have not been able to locate a cam.
I am also considering a solid lift roller.
What would you recomend??
engreps is offline
Old 03-31-2003 | 08:27 AM
KAAMA's Avatar
Make life a little easier on yourself and your boating experience and go with a HYDRAULIC roller cam---I am 95% sure you'll be glad you did!
KAAMA is offline
Old 03-31-2003 | 12:22 PM
blown1500
Try the Iskenderian 396284294. Ask for Ron Iskenderian and he will get you one ground for the MK V block in a couple of days and it will outrun even the 741 Crane. If you still want the Crane, they can usually make one on a billet that has a steel distributor gear and run the Comp Cams Composite distributor gear. The Crane is an excellent choice, though!!!
dmaxx3500
19
05-18-2008 07:59 PM
tomas_wallin
2
01-25-2007 09:56 AM
JohnSchiavarelli
2
07-07-2004 02:48 PM
Leathl_WS6
55
12-10-2003 08:07 PM
Drew
1
02-05-2002 01:11 AM
