Help! Pilot bearing - Do I need it? >
Old 03-31-2003 | 09:06 AM
GNJ2
Default Help! Pilot bearing - Do I need it?
I am using jack shaft kits in a 32 Skater. The kits came with pilot bearings (non-serviceable needle bearing type) for the input shafts going into the crankshaft. I have been told to disgard these, being that these are not necessary and will only be a problem later on. Since the drive plate is bolted to the flywheel and offers support to this shaft, it does make some sense. Can anyone shed some light on this for me?
Thanks - Gary
Old 03-31-2003 | 10:04 PM
Tinkerer's Avatar
You don't need them.
Tinkerer is offline
Old 04-02-2003 | 12:17 PM
sterndrivespec's Avatar
if this is a bravo setup i would use some kind of pilot bearing.we fixed a 42 fountain with staggered engines that another shop had replaced the forward engine in.after about one hour of running the flywheel housing would crack.they replaced the housing three times before the owner brought the boat to us.it never had another problem.
sterndrivespec is offline
Old 04-02-2003 | 12:40 PM
GNJ2
Default Pilot bearing
Thanks for the info. I knew these must have been a reason Mercury included these.
Old 04-02-2003 | 08:53 PM
Tinkerer's Avatar
The pilot bearing is installed in the end of the crankshaft isnt it.. If that is the case it wont change anything on the flywheel.
Tinkerer is offline
Old 04-03-2003 | 05:49 AM
Mbam's Avatar
Offshoreonly Advertiser
There is only a single ball bearing in the adapter that mounts on the flywheel housing, the shaft then engages the drive plate. In addition to moving around under load, the center hub on most production drive plates have lots of run-out. So the drive plate causes the U joint flange to orbit, or is not strong enough to prevent the flange from orbiting with the load of the driveshaft on it.
The pilot bearing keeps everything concentric - do not run without it and if it is showing lots of wear check the driveplate, the alignment of the engine to the transom and the balancing of the driveshaft.
Mbam is offline
RutRow
0
05-16-2005 10:39 AM
Wardey
10-08-2002 08:54 AM
