upgrading fuel lines? >
Old 04-01-2003 | 07:20 AM
dyno's Avatar
Charter Member #655
Default upgrading fuel lines?
last year when we dynoed SuperV's motor it appeared that the fuel delivery had a little to be desired. Would it make any differance if we use 1\2 or 5\8 lines with a stock belt driven fuel pump?can the out feed be altered on the pump to a larger size?
If your boat has a sail do you ride a horse to the ramp?
dyno is offline
Old 04-01-2003 | 11:09 AM
KCHOTBOAT's Avatar
Charter Member #737
replace the stock pump half of the merc pump with a HV carter pump.
KCHOTBOAT is offline
Old 04-01-2003 | 06:20 PM
dyno's Avatar
Charter Member #655
are they a copatible switch? I was told once before that you need to have a custom dog leg mage to run the pump? do you have a part # for the carter pump KCHOTBOAT?
dyno is offline
Old 04-02-2003 | 05:26 AM
dyno's Avatar
Charter Member #655
ttt
dyno is offline
Old 04-02-2003 | 11:02 AM
KCHOTBOAT's Avatar
Charter Member #737
I bought the standard Carter HV pump for a BB at a automotive
speed shop and bolted the bottom half of the pump to the stock top half of a Merc. CP Perfomance sell the same thing and they include a -10 inlet and -8 outlet. Cheaper at the an automotive store. pumps 120 GPH and self-regulated from 6-8 psi.
Old 04-02-2003 | 02:05 PM
dyno's Avatar
Charter Member #655
thanks man I'll give it a shot!
dyno is offline
Ran-Dom 32
25
04-11-2008 05:28 PM
ofshore
2
07-31-2005 09:30 PM
electrical1
11
06-26-2005 11:58 PM
Formula29
12
04-09-2004 11:59 AM
RonS
08-19-2003 08:15 AM
