Hydraulic Steering Remote resevoir
Charter Member #139 /Moderator/Platinum Member
Insted of having a pump with a resevior and then adding a secong resevior I saw a pump that was set up for a remote resevior once
Has anyone used this set up and if so who made the pump as I cant remember.
Official OSO boat whore
The circle racers use them all the time. I think that it's a trick way to go and can help solve some problems with air getting into the system. Having the tank mounted remotely will also clean things up a bit. I guess everybody just keeps on trying to use the merc/gm system instead of broadening their horizons. The only problem is that you'll have to come up with a custom bracket to mount it. This guy is up here in Milwaukee, but I know that they have what you need:
Behling Racing Equipment
262-783-7474
262-783-7474
