-   -   Stern lifting vs Bow lifting (https://www.offshoreonly.com/forums/general-q/47067-stern-lifting-vs-bow-lifting.html)
DRTOBE 04-05-2003 05:21 PM
Can anyone tell me waht prop design would work best for my 1984 26' Nova spyder with twin 400hp small blocks. My boat is a heavy "6700" lbs I am running 25 Pitch ballistic SS on them at 5200 rpms. I was thinking of getting Mirrage plus' or two "stern lifting" 4 blades.............HELP!!!!!!!!!!!
DRTOBE 04-05-2003 05:54 PM
Big Girl
She's a big girl and has alot of hull in the water even @ WOT Just dont know if the 4 blade stern lift would give me more top end than the mirage plus?
Ric232 04-05-2003 07:15 PM
Your boat probably needs a lot of help "carrying the bow". Since the drives are most likely mounted deep, the Mirage Plus (not the old Mirage) will most likely work best.
HOUSTONPROP 04-07-2003 01:31 AM
sternlifters raise the complete boat
If you can try a hydromotive 22 four blade or the 22 pitch Bravo they actually lift the complete boat not just the stern/good luck/Darin
Ric232 04-07-2003 08:38 PM
Re: sternlifters raise the complete boat
The Hydromotive IV lifts the stern more than the Bravo 1. The Bravo is more of a bow lifting prop. Hydromotive's new IV-X supposedly carries the bow a little better than the IV.
Mr. Demeanor 04-08-2003 12:22 PM
Try a Merc Rev4. They are made for heavy boats. I have an old Liberator and see more stern and bow lift plus better speed with the Rev4. All the three blades i tested would blow out as I trimmed up. The Rev4 stays hooked and allows me to trim up the nose quite a bit higher. Worth a test drive if you can find one.
