Hot spots in headers >
Old 04-07-2003 | 04:21 PM
F1campion
Unhappy Hot spots in headers
I have hot spots in one of my CMI(?) headers on my HP500EFI where the chrome has discolored. My impeller failed about a year ago and I replaced it on the dock. When I returned from vacation I had the motor backflushed and the ECM checked for any overheating codes. No codes found. Since then the spots appeared and appear to be getting worse. Is it the impeller pieces? Also that same muffler tip looks like it also got really hot and is discolored. All of this seems unlikely since I have never seen my temp gage reach more than 170 deg. F.
Old 04-08-2003 | 02:09 PM
F1campion
Wow 36 views and no replies??????
Ok - does anyone else have any discoloration in their headers? At least let me know that. A simple yes or no will work.
Old 04-08-2003 | 08:40 PM
paradigm shift's Avatar
No discolor on my CMI headers. Are you getting or does it appear to have the same amount of water out each exhaust? If not you could have a piece of impeller floating around still.
I am not sure where on the header you see discolor. Maybe that will help. Headers are polished stainless and discolor can be polished off once you find and fix the problem. Suggest you have polishing done unless you are a glutton for punishment. It ain't easy.
paradigm shift is offline
Old 04-09-2003 | 06:42 AM
Scott's Avatar
Charter Member #30
Is your 500EFI modified or stock? Does it have a water pump or a crossover?
I have Steps & Bubbles!
Scott is offline
Old 04-09-2003 | 04:31 PM
F1campion
Stock with a water pump.
Can someone tell me the flow path from the impeller to out the tip. i have had the cooling system flushed twice now. i was thinking about removing the header myself and trying to flush it clean.
Old 04-10-2003 | 09:27 AM
Nordicflame's Avatar
Smile Pieces...
I fried an impeller a couple years back and had it changed under warranty. After slightly eratic temps I was glad I pulled the hoses for inspection afterwards. I had chunks of rubber wedged in the power steering cooler AND the oil cooler. I was really surprised that these pieces could travel that far down stream through those small openings.
Bottom line is THEY DID. Pull all of your hoses from the seawater pump to the recirculating pump and to the exhaust.
You may be suprised what you find
Later,
Dave
Nordicflame is offline
Old 04-16-2003 | 01:10 PM
F1campion
Thanks everyone!
I guess it stands true:
If you want something done right do it yourself.
JBoat
07-29-2008 03:14 PM
MYSTICSUN
Southeast US
18
06-07-2008 11:18 AM
tripps
02-22-2007 08:34 PM
berns29scarab
09-07-2006 04:33 PM
JB4Boyne
03-24-2006 11:55 AM
