Thru hull tip sealant >
Old 04-16-2003 | 10:48 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
Default Thru hull tip sealant
Will plain ol silicone work as a sealant behind the trim rings on exhaust tips? Will see alot of under water exposure. Or is it better to go with 4200?
US1 Fountain is offline
Old 04-16-2003 | 11:19 PM
paradigm shift's Avatar
I think most will say use the 4200. I have used urethane caulk. I know silicone is good and would probably work but not the best in my opinion. Make sure your transom holes have been sealed (epoxy or fiberglass) real good if haven't already so no wood is exposed also.
paradigm shift is offline
Old 04-17-2003 | 07:53 AM
ren3
Paradigm is right on. Silicone is not for underwater use, and it is usually stated on the product labeling. I do not use silicone for anything on a boat. Fast cure 5200 or 4200 are so far superior. The advice about sealing the raw wood is the most important piece. Even with the urethanes, raw wood edges will come back to haunt you. Always seal them with epoxy, not polyester. Polyester resin has very low adhesive qualities and should never be used to seal wood if epoxy is available, especially raw edges.
Old 04-17-2003 | 10:42 AM
Official OSO boat whore
Silicone will work ok. As long as you didn't over cut the holes, you'll have a good 3/8" gasket. I wouldn't use it below the waterline though. The problem with some of the better sealants is that they will be almost impossible to remove. As for clean up, 3M make an adhesive remover that takes the dried silicone caulk right off.
Cord is offline
Old 04-17-2003 | 06:37 PM
H2Xmark's Avatar
4200, simple, or 5200 if you never want to take it off again
H2Xmark is offline
Old 04-17-2003 | 08:11 PM
CAP071's Avatar
USE 4200 I DID AND IT WORKS
CAP071 is offline
17
01-24-2007 07:04 AM
VIPER7
4
08-27-2006 09:48 AM
Danny_Ocean
9
02-16-2005 02:12 PM
US1 Fountain
Fountain
1
02-29-2004 08:19 PM
THRILLSEEKER
8
04-21-2003 10:18 PM
