Houston Propeller RULES!!!!!!!!!
Sent my prop to Darin over the winter like so many others here did. Had the boat out last weekend at LOTO. The best way to describe it is, " It runs like a raped ape" Unbelievable amount of performance gain, better hole shot. better top end. Darin, you RULE man!!!!!!!!! Thanks again, 88
Anyone looking to get a hold of Darin, his email addy is [email protected]
88 MACH 1, how much did you gain on the top end? Did you get it labbed or cupped or what. I was thinking of getting mine tweeked.
Balanced, labbed, cupped, and polished. Top end has to be at least 10 mph. Went from a 4 blade 22p to a 3 blade 23p mirage withall the work done. Talk to Darin, give him as much info as you can about your boat and he'll set you up. Later, 88
:confused: :rolleyes: :confused:
:confused: Me too!
Originally posted by 88 MACH 1 Balanced, labbed, cupped, and polished. Top end has to be at least 10 mph. Went from a 4 blade 22p to a 3 blade 23p mirage withall the work done. Talk to Darin, give him as much info as you can about your boat and he'll set you up. Later, 88 |
Not trying to campare, I was running the wrong prop for my boat. After talking to Darin, his suggestions and work on the 3 blade made all the difference. No one else could give me the info I needed on the right prop for my boat. Darin set me up.
Sounds like you got the right prop now!
Yes, I do, now looking forward to LOTO Memorial Day Weekend
| All times are GMT -5. The time now is 12:20 PM. |
