Dumb q about speedmaster drives? >
Old 04-22-2003 | 07:02 AM
Default Dumb q about speedmaster drives?
Just out of curiosity do you have to use a transmission with speedmaster drives?
THRILLSEEKER is offline
Old 04-22-2003 | 07:18 AM
Ted G's Avatar
yes
www.cbpba.com
Ted G is offline
Old 04-22-2003 | 04:05 PM
45sonic's Avatar
To second that
YES
I have #3 drives behind 750 Cobras w/ transmissions
45sonic is offline
Old 04-22-2003 | 06:06 PM
Panther's Avatar
Frank's Marine Service
You can also use crash boxes
Panther is offline
Old 04-22-2003 | 07:01 PM
mcollinstn's Avatar
You only "have" to use transmissions if you want your boat to back up or sit still if the motors are running.
I'm not trying to be a smart@ss, a Donzi nut (goes by Geoo) has a zillion horsepower smallblock 18 footer with a DIRECTDRIVE Arneson (to save weight and space).
My old outboard dragboats had no teeth on the reverse gears to save on friction and were locked in forward.
Some of the turbine boats use direct drive with a "brake" on the output shaft to be able to stop the prop around docks without spooling down the motor.
Speedmasters and TRS drives have no shifting capabilities inside them.
mcollinstn is offline
Old 04-23-2003 | 08:10 AM
So are there any drives other than TRS and SM that do not have shifting capabilities? How about Arneson, Pulse, and Kamma?
Old 04-23-2003 | 08:25 AM
They all need trannys too.
And they dont reverse rotation in the drive. So you need a tranny that has full power capabilities in both directions, or you have to reverse rotate an engine.
Probably more than you wanted to know.
Gary
Gary Anderson is offline
jeffaker
12-16-2005 11:54 AM
jeffaker
09-30-2005 02:04 PM
Comanche3Six
11-28-2004 04:17 PM
CIG3
06-24-2003 11:43 PM
das boot
Magnum Marine
2
03-08-2002 08:06 AM
