Rev Limiter on ECM or Safe Mode >
Old 04-24-2003 | 03:27 PM
Elite Marine's Avatar
Default Rev Limiter on ECM or Safe Mode
On a MEFI3 ECM, how does the ECM determine the load and RPM to limit over reving? Does it use the throttle position and RPM?
If so, is it possible that the Dyno is putting too much or too little load on my engine at the higher RPMs and the ECM is detecting the throttle setting relative to RPM and going into safe mode?
I have exhusted every test in the manual and nothing has worked. I have traced all the discreet system wires and they all ohm out good. I have removed, tested or replaced all senders and sensors. Is it possible that the engine is fine and the method of running it up to speed and load is causing the ECM to go into safe/limp mode?
Or am I just SCREWED!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!?????????? ????
Elite Marine is offline
Old 04-24-2003 | 04:44 PM
Scott's Avatar
Charter Member #30
I don't want to be negative here. But from what I have read on this board I thought the computer stored the over rev code?
I have Steps & Bubbles!
Scott is offline
Old 04-24-2003 | 05:55 PM
Thats not negative, thats correct. Except my ECM goes into safe mode and when I hook up the scan tool, I don't get any codes.
I've tried this with 2 ECMs, same results.
Old 04-24-2003 | 06:44 PM
rpm
Kirk, bring it up. If we can't fix it or determine what's wrong with it so you can fix it, I won't charge you.
Rod
Old 04-24-2003 | 10:03 PM
Mr. Demeanor
Thats an offer hard to refuse considering your frustration.
Old 04-24-2003 | 10:38 PM
28Eliminator's Avatar
Kirk, that is the best offer you are going to get, and not that far away either. Rod that is a great offer, especially when it is not a stock type setup. I am really interested in the cause of this. It just don't make sense, but then again when the problem is found, it will make sense. Good luck!
28Eliminator is offline
Old 04-25-2003 | 08:03 AM
I agree, Rod is a great guy and has helped me alot already. I just don't want to overlook a simple issue before going that route.
How do most Dyno Shops run up EFI Supercharged engines? Do they run them up under load and hold RPM? Is it possible that the engine is fine but the dyno is causing the ECM to go into safe mode due to the throttle position vs load?
If anyone familiar with the recommended run up on a dyno could answer this, I may have found my problem.
Old 04-25-2003 | 08:21 AM
rpm
Kirk, The only way to do a valid dyno test throughout the range is to run it up under load.
No, throttle position has nothing to do with the load sensed, examples from both sides. Its very easy to run a non loaded engine to its rev limiter, like in neutral and conversely, if it were load sensitive with respect to throttle position you'd never be able to get it on plane because it would have full load long before you ever got on plane.
Rod
mcprodesign
Fountain
4
05-19-2008 06:37 PM
D Harry
4
06-28-2007 07:20 AM
D Harry
0
06-23-2007 04:26 AM
Mike Paula
9
10-08-2006 03:46 AM
THRILLSEEKER
6
07-25-2002 07:30 AM
