Trim & K-plane pump oils??? >
Old 04-30-2003 | 06:28 PM
blown formula's Avatar
Question Trim & K-plane pump oils???
Here's the deal.....
I read in my Clymers Mercruiser manual that the Oildyne/Singer pump (plastic reservoir) and the Oildyne/Eaton (metal canister) are interchangeable. Also, it states the Singer (Plastic tank) should be filled with SAE 10w-30 or 20w-40 engine oil...... My Merc dealer says to use the Merc Fluid only in both! AND to make matters worse, the metal canister pump label says to use ATF only !!!!
What is the right/correct thing to do here? !!!
I would really like to bleed the hydraulics this weekend, so I need to know asap!!
Thanks in advance.
blown formula is offline
Old 04-30-2003 | 06:52 PM
Iggy's Avatar
Any of the choices you mentioned. As long as you use what's already in the reservoir. Don't mix fluid types.
When I had to flush my trim system I refilled it with 10-30 Mobil1.
Iggy is offline
Old 04-30-2003 | 06:56 PM
cuda's Avatar
I filled mine with ATF.
cuda is offline
Old 04-30-2003 | 07:21 PM
Official OSO boat whore
I used straight 30w. It's a hydraulic pump. If you could control the corrosion water would even work. Don't sweat it.
Cord is offline
Old 04-30-2003 | 08:08 PM
Excellent!! The pumps & reservoirs were disassembled, cleaned & new seals installed... so they are "virgins". The fluid in them was very, very thick & milky with junk in the bottom of the reservoirs....... I think I'll go with the 10W solution!!
Old 04-30-2003 | 09:29 PM
mcollinstn's Avatar
ATF in my trim pumps and tab pumps in the Formula (from the factory).
ATF in the Bennett pumps in the Sea Ray (from the factory).
mcollinstn is offline
rrentsch
3
09-10-2007 06:10 PM
point92mach
4
07-15-2007 03:19 PM
ratman
01-26-2006 07:48 PM
Poorsche
2
04-23-2005 06:48 PM
GRS
1
06-07-2004 06:14 AM
