oil Cooler
Old 05-02-2003 | 10:46 PM
convincor's Avatar
Default oil Cooler
Swapping from 330hp to a stock(right now) 502, 415hp
Want to replace oil cooler. What should I get.
Would a 16" combo cooler work?
I'd run a 'Perma-Cool' thermostat.
Will this set-up work if I were to build the motor later?
convincor is offline
Old 05-03-2003 | 07:27 AM
I did the exact same swap, used the Eddie Marine large and temps at the filter pad were a consistent 195 to 215 with the 502.
BadDog is offline
Old 05-03-2003 | 08:10 AM
convincor's Avatar
did you use a thermostat with that cooler?
t500hps
07-17-2012 09:23 AM
J. Hordubay
13
10-02-2008 01:55 PM
31scarab31
2
02-29-2008 04:14 PM
slik22
Wanted
6
01-08-2008 04:13 PM
patrick22309
5
06-20-2003 05:53 PM
