-   -   Can the power steering pump be mounted on the other side? (https://www.offshoreonly.com/forums/general-q/49216-can-power-steering-pump-mounted-other-side.html)
p4-33 05-08-2003 03:34 PM
Hey Cuda, redundancy is everything when it comes to steering. Last year I was at speed in Lake Cumberland and broke an alternator belt, which threw off the PS belt in the process. I took a HARD left and damn near ate the shore.
I just rigged a Latham system for my boat this winter, on a boat that originally only had one pump. Randy from Cobra Power (305 893-5018) has a warehouse full of parts, both new and used, and he was able to set me up with a pump, brackets, cooler, etc.
Call Ted Chance from Latham (800 422-7267) and he can set you up with a"Y" valve to accomodate twin PS pumps, as well as all of the brass fittings to make it happen.
Good luck... Summers' comin'!
Brian
cuda 05-09-2003 08:27 PM
Thanks Brian, I'll check with them.
Audiofn 05-10-2003 10:40 PM
Thanks for all the help :D:D
