Help, someone with 280 k-planes and access to their boat >
Old 05-05-2003 | 05:57 PM
formula31's Avatar
Question Help, someone with 280 k-planes and access to their boat
I need someone to measure the rise on std 280 k-planes. If someone could do this for me Id really appreciate it. Take a long straight edge and hold it up to the bottom of the boat so it comes straight back at least as far as the end of the k-plane. Measure the distance from the straight edge to the k-plane at the hinge and then again at the end of the k-plane. This will give me the rise info I need. Oh, with the k-plane up all the way please. Thanks.
formula31 is offline
Old 05-05-2003 | 08:08 PM
3/4 of an inch to the bottom of the hinge and 4.5 inches at the end
Bajaforce is offline
Old 05-05-2003 | 09:09 PM
formula31's Avatar
Thanks, Wow, I was gonna set mine at 2.5 and I thought that might be too much but I guess not.
Old 05-05-2003 | 09:54 PM
Almost the same as Bf. Mine are mounted 1" off the bottom. At the end of the Kplane, running a straight edge flush with the bottom of the boat, I'm at 5 inches.
Griff is offline
Old 05-05-2003 | 09:57 PM
Keep in mind, the transom angle will have a small effect on the amount of rise. You should just have to mount then 1/2"-1" off the bottom of the boat.
Griff is offline
olredalert
Swap Shop
6
08-28-2008 08:55 PM
BLOWN85
Velocity
35
07-28-2008 07:30 AM
freshwaterfiend
Wanted
4
04-12-2008 10:13 PM
Velocity Vector
14
12-28-2007 09:07 PM
Jgray
Velocity
14
03-15-2006 08:59 AM
