valve stem size revisited >
Old 05-08-2003 | 03:32 PM
later's Avatar
Default valve stem size revisited
i asked the question as to what size are the valve stems on my
98 hp500s and got the responds of 3/8, and since no one else responded i quessed that to be correct, although in my searchs i keep coming up with 11/32, how about it some of you guy's that work on these things every day 3/8 or 11/32.
later
later is offline
Old 05-08-2003 | 03:44 PM
bobby daniels
3/8'S
3/8'S FOR SURE ALL i'VE SEEN ,ALOT
hope this helps
Old 05-08-2003 | 05:11 PM
later's Avatar
thank you
later
later is offline
Old 05-08-2003 | 05:30 PM
I'm glad you backed me up bobby.
Merc stuff for the most part is standard GM. Standard GM valves are 3/8.
I know what I'm talking about (most of the time)
DAVE
Dave F is offline
Old 05-08-2003 | 05:31 PM
bobby daniels
Default valves
no problem any time I know yours is not an EFI but
most of the EFI's came with innconel exhaust which is a good idea
Old 05-09-2003 | 07:58 AM
later's Avatar
is that to say that the stock mercruiser valves on the 500hps are not inconel material on the exhaust side and stainless on the intake?
later
later is offline
Old 05-09-2003 | 09:16 AM
bobby daniels
Two years the 500's came with non innconel exhaust but I think merc wised up and now they all do ,
For what its worth I would run inconel exhaust ,good manley intakes and good springs and rockers and drive it and enjoy it ,the rockers (gold ) have weak axle bearings and make me nervious to use ove 200 hrs of normal use (normal) ,,good luck ,,,,,later ,
Bobby
Bryan Rose
0
12-21-2006 09:31 PM
Hot Boat
1
09-27-2006 07:35 PM
Viper31
0
12-22-2005 09:13 AM
WILDTHING TAZ
0
12-09-2003 06:33 PM
later
1
04-27-2003 01:18 PM
