Gen VI Head Bolts >
Gen VI Head Bolts
Gen VI Head Bolts
Old 05-14-2003 | 04:32 PM
convincor's Avatar
Default Gen VI Head Bolts
Chevy books say to use oil on threads not sealant on a gen VI 502.
Pulled heads off and GM used sealant
What should be used?????
Holes are not open to water jackets.
convincor is offline
Old 05-14-2003 | 04:39 PM
First off pop for a set of ARP head bolts. They are not that much. Then use their assembly paste and follow their torque specs. Read up on this here;
http://www.offshoreonly.com/forums/s...&highlight=ARP
Been covered with good answers.
Tim T.
BadDog is offline
Old 05-21-2003 | 03:22 AM
formulaF302
I have re used my head bolts in my Gen VI motors 3 times now....last time when I switched to wold products heads. I had to put spacers under them to fit, and lubed everything with 30 wt oil....but all is still fine. I have since found out however that those bolts are not designed to be re used since they are a "stretch to yeild" type of bolt. I've had no problem YET....but am starting to get concerned after reading this forum.... Glenn
Old 05-21-2003 | 07:34 AM
Cignificant's Avatar
Same here Glenn - third go round on blower motors and no problems. Next time I'll replace them.
Steve Gresham
'03 Donzi 33ZX
Cignificant is offline
Old 05-21-2003 | 08:38 AM
It's better to use the assembly lube rather than oil on blind tapped head bolts.
It's possible to "hydrolock"(compress oil in the hole) the bolt which will give you a false torque reading.
Because the holes are blind sealant is not needed. The assembly lube will give a more accurate torque reading.
DAVE
Dave F is offline
Old 05-21-2003 | 09:13 AM
bobby daniels
DAVE your right and thats very common !!
I could not get away with using the same head bolts 3 time period ,,damn you guys are lucky and change to ARP their great
Washers (more than one ) is impossible to get the right reading
Old 05-27-2003 | 02:45 AM
formulaF302
I did use the ARP washers as spacers below them(even though I did'nt like the idea of doing it) ...and although I used a very light coat of oil on the threads I did use assembly lube on the washers and below the bolt heads. Maybe thats what saved me cause things are still Ok after running this week.
Ken N
8
09-24-2008 02:35 PM
GNJ
3
05-23-2007 12:15 PM
alecsammy
4
11-11-2006 02:32 PM
speedball
5
05-28-2004 12:28 AM
DanB
5
12-15-2002 05:44 AM
