-   -   morse cables on bravo shift bracket??? (https://www.offshoreonly.com/forums/general-q/50031-morse-cables-bravo-shift-bracket.html)
puder 05-15-2003 01:37 AM
where can i get the cable ends for morse cables that will work on the bravo shift plate? I also need some kind of reatined thign. The 33c cables have the notch in them that you ususlaly just clamp over (liek eth thing on eth bottom of gaffrig throtlles) but what do i use on eth shift bracket?
also what cable ends should i use for the carb? I was just goign to use the same ones that are on the throttle end and bolt them to the dominator.
Cord 05-15-2003 06:14 AM
CP performance carries a plastic end that will work. I don't know where to get the brass ones. They may be a merc item.
