Cam degree Question >
Cam degree Question
Cam degree Question
Old 05-16-2003 | 11:20 AM
Scott72
Default Cam degree Question
I have one more question from my engine build sheet. The cam in a Comp Cams XM270.
226 in. 236 ex @.050
.544 in .547 ex @ 112
On the sheet is say's "Cam in @ 110.5"
Maybe some of you engine guru's could explain what exactly this means in terms of this Cam. Just trying to expand my knowledge base.
Thanks in advance,
Scott
Old 05-16-2003 | 11:25 AM
bobby daniels
It s advanced 1.5 degrees
Old 05-16-2003 | 02:04 PM
Scott72
Thanks Bobby. What do I gain by the cam being advanced 1.5 degrees? I have rebuilt motors etc...but always installed the cams straight up. Degree a Cam is kinda Greek to me.
Old 05-16-2003 | 03:02 PM
bobby daniels
Scott its a fairly long topic and I will be glad to help ,but in short it makes the power come on at a lower rpm than straight up and retarding it works the opposite way ,but 1.5 degrees is no worth anything I think thats just the way everthing lined up and he left it there instead of making it straight (Timesaving) 4 degrees is common either way not 1.5 degrees
hope this helped alittle if not p.m. me
Old 05-16-2003 | 10:18 PM
220BR
I never can keep these cam things straight. The XM270 has a centerline of 108* (I believe) and an LSA of 112. So that means the cam is ground with 4* of advance. If it was installed at a centerline of 110.5*, isn't that 2.5* retarded?
Or am I retarded?
superiormgmtco
3
02-10-2007 03:42 PM
BOBBYGONZO
12-19-2002 08:03 PM
traviss
8
09-30-2002 03:43 PM
DanL
6
05-21-2002 04:00 AM
