oil pressure? >
oil pressure?
oil pressure?
Old 05-18-2003 | 02:48 PM
mats's Avatar
Default oil pressure?
My oil pressure gauge reads 20 psi at idle, then increases to 30 psi at 1000 rpm and then stays there all the way to 5000 rpm. Is that normal on a 1999 502 MPI?
mats is offline
Old 05-18-2003 | 03:43 PM
CESSNA
with an electric gauge it very possible try hooking up a mech and check it
Old 05-18-2003 | 06:04 PM
PureEnergy
I agree, always double check with a mechanical gauge. I had false reading on my electric ones, but the mechanical showed it was fine. I replaced the electric senders and now they read right.
Old 05-19-2003 | 10:03 AM
madbouyz's Avatar
I have the same engine and after its last oil/filter change the pressure seemed to go down low also.I thought it was a bit unusual because nothing else was done and all materials used were the same as always.
I changed the filter again (only had about 2 hrs on the other one) and voila.. the pressure is back up to normal, or possibly better than it ever was !
Don't ask me why I'm just gald that for once the fix was cheap and easy !
madbouyz is offline
Old 05-19-2003 | 10:08 AM
mats's Avatar
Was it the standard merc filter both before and after?
mats is offline
Old 05-19-2003 | 11:24 AM
madbouyz's Avatar
NO.. Very limited choice of most things here in the triangle but I Like to go with a bigger filter if I can.. Had used A fram since initial run in oil change with no problems.Then this happened and I went back to the teeny Merc one and its OK..it seems !
madbouyz is offline
GoCiggie31
7
08-19-2007 06:07 PM
dockrocker
17
08-05-2005 09:30 PM
mleslie951
27
11-08-2004 08:03 PM
FlyFast
13
05-10-2004 11:39 PM
