Help Trs Outdrive >
Help Trs Outdrive
Help Trs Outdrive
Old 05-19-2003 | 07:16 PM
82LAVEY's Avatar
Angry Help Trs Outdrive
I was running my boat this last weekend and slow down then got back on it and it felt like it was in neutral if i idle it it would move as soon as i gave it some throttle it would start slipping trans oil look good didn't hear any different sounds coming from it check linkage i am lost is it toast thanks
82LAVEY is offline
Old 05-19-2003 | 07:51 PM
Payton's Avatar
Charter Member #927
Did you spin the hub on your prop? Unless it's a solid hub, then yes sounds like you lost the plates in your trans. Did you smell the trans oil?
Check your prop first though.
Payton is offline
Old 05-19-2003 | 07:54 PM
82LAVEY's Avatar
Yes I check the the prop it is a sold hub but checked anyway the trans oil smell normal and looks normal
82LAVEY is offline
Old 05-19-2003 | 08:23 PM
Mbam's Avatar
Offshoreonly Advertiser
What does it feel like if you turn the prop? Any crunchies? Drain a little oil out of the drive and see what it looks like.
Mbam is offline
Old 05-19-2003 | 08:27 PM
82LAVEY's Avatar
I have not drained any oil yet but when I turn the prop every feels fine
82LAVEY is offline
Old 05-19-2003 | 08:54 PM
not trying to insult you inteligence but is the trans oil level up to par?
Also does the engine rev way up when you apply throttle with it in gear, like it would if you where in neutral??
THRILLSEEKER is offline
Old 05-19-2003 | 09:22 PM
82LAVEY's Avatar
yes it is to the full mark and yes the engine does rev up just like it was in neutral
82LAVEY is offline
Old 05-19-2003 | 11:12 PM
Audiofn's Avatar
Charter Member #232
What trannies do you have? Merc trans or B&M??? Maybe you broke your pump?
Jon
Put your best foot forward!
Audiofn is offline
Old 05-19-2003 | 11:40 PM
82LAVEY's Avatar
It is a mer cruiser is there a sheer pin in there some ware
82LAVEY is offline
Old 05-20-2003 | 06:29 AM
I had something similar happen to mine. There is a seal on the clutch pressure plate, which holds the oil in. This deteriated and popped out slighly jamming the pressure plate and destroying the seal. So no engagement of gear. I had a noise when this happened as is jammed still touching the clutch plates, and they slipped. Thought Id blown it.
Turned out it was a good job it did as some of the internal roller bearings used for reverse were seized, and one of them had its shaft spinning and wareing through its housing. This was a result of poor lube. From a holed cooling tube.
Now I am renewing shaft bearings and all seals on both boxes. + some of internal roller bearings.
Out of interest, what gear oil are you using.
richard is offline
