Temp Gauge problems again!! >
Old 05-26-2003 | 10:09 AM
97BossHammer's Avatar
Thumbs down Temp Gauge problems again!!
Ok this thing has me very confused. So far I've replaced the Tstat and the temp sender. I have checked the gauge itself also by touching the wire against a ground and it registers. The fuses are also good. I've pulled the dash and all the wires are connected. I can't figure this thing out for the life of me. Anybody know what else to check? I've done basically all I know to do.
97BossHammer is offline
Old 05-27-2003 | 11:15 AM
anyone?
Old 05-27-2003 | 11:57 AM
Hammer whats the temp gauge doing/reading, need more info
Doug
Doug E. is offline
Old 05-27-2003 | 01:10 PM
When you turn the key on it will move up to the 100 degree mark and thats as far as it gets. I was thinking first the tstat might be stuck but thats not the case, I've replaced it. Then I thought it might just be the sender but I've also replaced that as well.
Old 05-27-2003 | 01:38 PM
Scott's Avatar
Charter Member #30
Do you have thread sealant on the sender?
I have Steps & Bubbles!
Scott is offline
Old 05-27-2003 | 02:15 PM
StrikinLightnin's Avatar
Did you use a Mercruiser gasket for the intake/thermostat housing?
The gasket has brass rivets in it so the sender will
be able to conduct correctly.
StrikinLightnin is offline
Old 05-27-2003 | 02:38 PM
.......Yeah, what Scott and 35 Lightning said !
Take a volt/ ohm meter touch the
base of the sender ( sender installed)
with one lead, touch the other lead to
a known good ground, meter set on
ohm's, should read zero ohm's.
jt
JaayTeee is offline
Old 05-27-2003 | 07:40 PM
Yeah the gasket is merc, it has the brass rivets in it, i didn't put any sealant on it.
jt29olhp500s - I haven't done that yet...but what I have done is taken the sender wire and touched it up against a ground and it pegged the gauge out so I know the gauge is working. Something's got to be messed up somewhere, I just don't know what else to do.
Old 05-28-2003 | 09:18 AM
Hammer run a new ground to the gauge. I had a similar problem and that fixed it.
Doug E. is offline
Old 05-28-2003 | 10:49 AM
1 more easy check that I should
have mentioned last post,
take a jumper wire, touch 1 end to
battery neg, the other end to the
base of the sender,
this will eliminate the bad sender
ground possibilities.
jt
JaayTeee is offline
