Do I need Drive Showers on TRS >
Old 06-05-2003 | 08:30 AM
Leathl_WS6's Avatar
Default Do I need Drive Showers on TRS
I have a 84 330 Mercuriser with a TRS drive and Tranny. Since the tranny is inside the transom are drive showers needed or helpful
Thanks Rob
Leathl_WS6 is offline
Old 06-05-2003 | 08:38 AM
With a 330, use the $100 that a drive shower would cost and use it for regular drive maintenence. The TRS really doesn't need it with that hp.
Gary
Gary Anderson is offline
Old 06-05-2003 | 08:45 AM
Leathl_WS6's Avatar
Boy you guys are fast with the replies.
Thanks.
How often should I maintenence it? And what all should I do. Just fluid change?
Rob
Old 06-05-2003 | 09:00 AM
Change the lube at leasts once each year. At the end of the season if it's cold there.
Take the drive off and lube the U joint/spline yearly.
Lube all the grease fittings on the gimbal several times a year.
Gary
Old 06-05-2003 | 09:12 AM
Wally's Avatar
Were doomed!
Unless you are getting a chaulky buildup on the upper part of the drive signaling you are heating it up a bit then i wouldnt worry about drive showers.
On my old TRS setup i switched to RedLine shockproof heavy oil and never had a problem of any kind......even had less of that little metal dust that you find on the magnet when changing oil at the end of the season!
-Wally
Wally is offline
Old 06-05-2003 | 12:12 PM
Leathl_WS6's Avatar
Thanks Guys.
No chalky build up that I can remember.
Old 06-05-2003 | 05:15 PM
Biggus's Avatar
I wouldn`t think there would be any benefit to installing a drive shower on a TRS because the TRS has a pump in it and the drive oil is constantly circulating from the lower unti, immersed in the cool water, to the upper gear housing.
Biggus is offline
Powerboat713
12-20-2007 10:49 PM
502ss
Drives and Lower Units
4
10-09-2007 02:42 PM
Craney
3
12-03-2006 04:33 AM
FunHome
9
05-20-2002 04:46 PM
Paul Kermis
1
03-23-2002 10:04 AM
