-   -   trs ? (https://www.offshoreonly.com/forums/general-q/51669-trs.html)
JUSTONCE 06-05-2003 12:07 PM
trs ?
On my boat then on the trailer even in neutral if i turn the prop with my hand (engine off of course) there is alot of resistance compared to spinning the prop in a bravo. I know The tranny may have something to do with this but my ? is to you trs guys are your props realtight to turn?
THRILLSEEKER 06-05-2003 01:24 PM
JO, both of mine are also "stiff" I often wondered the same thing. The gears in a TRS are always connected so everything is "always" turning, the shift between foreward, neutral and reverse in a TRS takes place in the tranny unlike a Bravo which shifts inside its own housing. So when a Bravo is in neutral there are a few less gears and shafts turning as compared to a TRS, hence less resistance,
Clear as mudd right;)
JUSTONCE 06-05-2003 01:30 PM
Cool thats kinda what I though since your turning the output side of the tranny too.
Gary Anderson 06-05-2003 02:25 PM
Yep, your turning everything from the propshaft to the plates in the tranny in a TRS.
Gary
