I bought a 1/2" spacer for my drive >
Old 06-06-2003 | 07:33 PM
MIKEHTMSR24's Avatar
Default I bought a 1/2" spacer for my drive
I have the Imco SC drive, I am understanding that a spacer for a stock Bravo will not quite match my SC. What will be the difference? I think the tail end of it will be the problem. I haven't seen the spacer and drive together since my boat is in storage several miles away.
If it doesn't fit is anybody interested in buying it?
MIKEHTMSR24 is offline
Old 06-07-2003 | 10:42 AM
bsag's Avatar
I would be interested let me know.
bsag is offline
Old 06-07-2003 | 06:36 PM
duunoit's Avatar
Me, too. Let me know what you want for it...
duunoit is offline
Old 06-11-2003 | 08:17 AM
Mike, I have a 2in spacer on my imco sc and it works fine, looks a little funny but gets the job done. I have been using it for over a year and no problems, I just check the bolts before I go out, never loosened up yet.
Catss is offline
Old 06-11-2003 | 08:02 PM
Default I think someone is making one to fit the SC
Thanks, I'm hoping I can try it out this weekend and see what happens.
Old 06-13-2003 | 07:00 AM
bikinilover's Avatar
What does a spacer do?
bikinilover is offline
Old 06-13-2003 | 03:27 PM
Default Their is a fine line on being too deep or
too shallow with your drive height. What you should do to obtain that perfect height try putting on a shortie 2" and then start going deeper so that you get the best top speed or somewhere in between.
HotRoddin is all about give and take.
The top speed is usually not the best take off and the best take off will not give U your best top end.
I know when I put on this 1/2 spacer I stand a good chance of losing some top end.
What I am hoping for is a better balance between slow cruising speed and top end.
The 1/2" spacer may even help my top end.
You don't know till ya try.
My 2" shortie gained me 3.5 to 4 mph. I was lucky enough to be able to water test with my stock foot and then remove it and put on a 2" shortie that same afternoon. Good accurate testing at is best. GPS to GPS.
Noel35
Wanted
1
10-30-2008 12:05 PM
JohnS
07-23-2008 08:40 AM
p729lws
Wanted
1
02-07-2008 03:25 PM
FASTERDAMITT
General Racing Discussion
4
03-09-2006 12:56 AM
MIKEHTMSR24
06-06-2003 07:30 PM
