formula for calculating valve overlap? >
Old 06-08-2003 | 08:22 PM
Vinny P's Avatar
I hate the winter!!
Default formula for calculating valve overlap?
What is the formula for calculating the amount of valve overlap?
Vinny P is offline
Old 06-09-2003 | 07:09 AM
Just add the numbers on the cam card from where the intake valve opens to where the exhaust valve closes.
DAVE
Dave F is offline
Old 06-09-2003 | 03:46 PM
220BR
Best way to calculate overlap is to add the Intake Open point to the Exhaust Close point. For example, my cam card lists IO=20*BTDC at 0.006" and EC=18*ATDC at 0.006". So, overlap at 0.006" is 38 crank degrees.
If you want to know it at 0.050", your card may not list IO and EC at those points. But the card should give you intake duration and exhaust duration at 0.050". Add 1/2 of the intake duration to 1/2 of the exhaust duration, then divide by 2 to get it in cam degrees. Subtract the Lobe Sep Angle (which is in cam degrees) from that number to get overalp at 0.050". So, for my (weak) cam, 212/2=106 + 218/2=109 == 215/2 =107.5 cam degrees of duration. 107.5-112(LSA) = -4.5 (my cam doesn't overlap at 0.05").
Hope that's what you were looking for.
Old 06-09-2003 | 06:07 PM
Vinny P's Avatar
I hate the winter!!
Thanks, that is what I thought. But when you run the numbers at zero valve lift, the numbers seem real high.
Vinny P is offline
Audiofn
24
12-26-2007 04:18 PM
Rebel_Heart
8
03-04-2006 05:36 PM
Toffen
07-28-2003 02:28 PM
26sonic
2
05-21-2003 10:05 PM
KAAMA
6
09-14-2002 10:22 PM
