Tailstock/engine allignment question?
Are there supposed to be some spacers or washers that go between the tailstock and the transom plate to allign the motor:confused: :confused: I dont remember taking any off but that was last October, and I could have easily forgotton:rolleyes:
When I look through the gimbal at the tailstock from the outside of the boat, the tailstock seems to be sitting way lower than it should be:confused: Any suggestions? |
Spacer
Yes , there is a leather like material with a split/spring washer in the centre that goes between the bellhousing & transom plate. Hope this helps you out. Check Bam's Mercruiser parts section & you will see what ya need.
John |
1 Attachment(s)
split washer goes on top of gimbal inner plate, tailstock sits on top of this washer. Leather washer fits around outside of split washer
1 Attachment(s)
alignment tool in place, raise/lower front of engine for alignment.
| All times are GMT -5. The time now is 01:12 AM. |
