Break in for rebuilt motors? >
Old 06-16-2003 | 07:09 AM
Default Break in for rebuilt motors?
Aside from the initial 20 min breakin on the hose, is there any other precautions to take...i.e. staying under a certain RPM range ro so many hours??
THRILLSEEKER is offline
Old 06-16-2003 | 07:31 AM
Ted G's Avatar
For the first ten hours try to vary speed every 10-15 minutes. No WOT for the first hour or so and then no more than short bursts for the next. Or you can run it like a race boat and go WFOT all day as soon as it hits the water And I try to change the oil after the first ten also.
www.cbpba.com
Ted G is offline
Old 06-16-2003 | 08:08 AM
Smitty's Avatar
I'm a firm believer in driving from day one the same way you are always going to drive it. I have done this with all my cars, boats, motorcycles and have never had engine issues.
Smitty is offline
Old 06-16-2003 | 09:52 AM
formula31's Avatar
Just avoid as much idling as humanly possible for the first couple hrs. And I change oil after 1 hr, then again at 10. Look at the oil and filter (inside) closely at 10 hrs.
formula31 is offline
Old 06-16-2003 | 10:31 AM
Wally's Avatar
Were doomed!
Yup! i'm the same way...if its gonna break its gonna break.....babying it is not gonna help anymore now or 10hrs from now.
-Wally
Wally is offline
Old 06-16-2003 | 03:45 PM
Krumbsnatcher's Avatar
Thumbs up
I all ways run mine 20 minutes at medium rpms just to ensure the rings are set, then it is full throttle.
If its going to go it will go then, it is only a matter of time we know it will eventually go.
"looks do matter!"
Billet Audio Covers .com High Performance for Sound
Krumbsnatcher is offline
Old 06-16-2003 | 09:07 PM
SSComp's Avatar
I have to disagree with with the beat it from day one principle. Race engines are only made to last a much shorter time.
Use NON-synthetic multiweight oil. Change after the first run. Use Non-synthetic oil for 10-20 more hours. My engine builder said Syn. lubes too well and the rings don't seat properly.
Try not to idle much for the first 5-10 hours and resist the urge to make bursts. Vary RPM often.
When I had my engines Dyno'd, Performance Research did not want to do a "full HP test" unless I forced the issue. They said they were not broken in.
If you have your engines dyno'd you'll find the procedure to be a building one...start slow and work up varying RPM as you go.
SSComp is offline
kvogt
Swap Shop
0
10-03-2008 10:48 AM
302Sport
09-19-2008 01:19 PM
32 thunder
07-09-2005 10:09 AM
bshzba
04-21-2004 02:26 PM
freeman1
03-03-2002 04:21 PM
