OK Time to prop this boat, Help. >
Old 06-17-2003 | 10:13 AM
fountain27ho496's Avatar
Default OK Time to prop this boat, Help.
Finnally solved my fuel delivery/miss problem.
Now I need a prop. this motor should run between
4600-5000, Last night tagged the rev limiter at 5200
twice. 68 on speedo(66gps) 1 person 80 degrees
water temp about 66. Bravo 26 four blade. 1.5 xz
large shaft. Pretty close to fountain perf. report.
It said 68 on radar @5100.
Would like to get this right the first time, wouldn't
everyone? I still have 3 B-1 props left from dialing
in the last boat. Any one have this package?
Of course I want to go 70 @4900-5000.
Hoping for some testing ability instead of buying
3 wheels to get it right. Thanks in advance.John
Anyone need a mirage 23 non plus, ballastic 25.
Both perfect 3 blades.
fountain27ho496 is offline
Old 06-17-2003 | 07:44 PM
paradigm shift's Avatar
I am no expert but it sounds like you are real close now. You can probably go to a 28p bravo1. May be a little to much with a full load but it will drop your RPM. Or you could have the 26 reworked. I do not have your set up but I do like having a spare prop. One for crusing everday use and one I have tweaked for those special occasions!! Find someone with a 28 you can try. Also most good prop shops will allow a trade on new props until you find the right one for a slight fee as long as you do not damage it testing. Perfomance boating = test - test - and more test. Isn't it fun!! Good luck on your set up. Just my .02.
paradigm shift is offline
Old 06-17-2003 | 09:08 PM
HOUSTONPROP's Avatar
Lightbulb test/test /test
yep/but the 26 is very workable, thinned with some cupping added should make it right on the $$$$$/ALSO HOW MUCH FOR THE 25 Ballastic I, have a home for it/Darin
HOUSTONPROP is offline
Old 06-18-2003 | 09:53 AM
Default Can't be without it....
Will thinning and cupping raise the pitch and lower
the rpm? I don't want to let it go if I dont have a back-up.
Can't afford to miss a day of boating in this state.
Do they make a 27 bravo? Should put me at 4900-5000
I paid 300. for the ballistic and this is an honest 15 min
prop. It blew out on me and the rpms were too high,
I took it right off. I can be reached at 248-683-8612
est 10:30-1:30 mon-fri. A reasonable offer. John
Old 06-23-2003 | 09:57 PM
Lightbulb pitch in increment's EVEN AND ODD #'S
All of the 3 blade mirage props for alpha and bravo out drive are in odd numbers, such as 17,19,21,23,25,27,29, all of the 4 blade bravo one propellers are in increment's even number's 22,24,26,28,30,32 Thanks for the reply on the ballastic, I know a few bass boater's that may need it .Darin
GCAT911
Prop Talk
17
10-24-2007 02:40 PM
slboatdrinks
Active Thunder
20
05-29-2007 02:01 PM
Sydwayz
Active Thunder
9
06-13-2005 01:13 PM
krakmeup
Superboat
14
11-20-2004 07:36 PM
WETTE VETTE
06-20-2002 01:11 PM
