Outdrive Gear Ratio Question >
Old 06-19-2003 | 03:48 PM
SoCalOffshore
Post Outdrive Gear Ratio Question
Why would or what would be the benefit of chaning the outdrive gear ratios from the standard 1:51 to 1:35? I have twin 525's on a 32' Schiada. The builder is advising going to 135 vs 151. Thanks for any insight.
Old 06-19-2003 | 04:06 PM
HyperBaja's Avatar
No need to change gears unless you cannot find a bigger prop.
HyperBaja is offline
Old 06-20-2003 | 05:30 AM
sterndrivespec's Avatar
i agree,dont waste your money
sterndrivespec is offline
Old 06-20-2003 | 06:19 AM
Turbojack's Avatar
What props are you running now? What RPM & speed? With the motors you have & 1.5 gears, I would not think that you need any bigger props than 32 or 34's. As stated above only need to go to 1.36 gear ratio is when you can not get a prop that is big enough. You can now buy props up to 36". Why is your builder telling you this?
Turbojack is offline
Old 06-25-2003 | 08:36 PM
splash n' dash
some guys around here change so they are twisting the gears and shafts slower ie less wear
Old 06-26-2003 | 12:03 AM
SoCalOffshore
because of cavitation issues with high pitch props
Old 06-26-2003 | 08:07 AM
Official OSO boat whore
The props at 34" and over are not as efficient and they suck getting on plane.
Cord is offline
Old 06-26-2003 | 08:34 AM
PatriYacht's Avatar
I have heard that 1.35 gears are stronger. Is that true?
PatriYacht is offline
Old 06-26-2003 | 09:22 AM
Reckless32's Avatar
Rough Seas Lie Ahead
Along the same lines, let's go the other way. What are the advantages/disadvantages of moving "up" in ratio? Just curious...
Reckless32 is offline
Old 06-26-2003 | 09:35 AM
I'm told that a (numerically) higher drive ratio and a taller prop will accelerate faster than a lower drive ratio and smaller prop. Why that is, I don't know.
Cord is offline
