Oil Capacity Question >
Old 07-05-2003 | 07:21 AM
cig1988's Avatar
Default Oil Capacity Question
I have 365 magnums and was under the impression it was 6 quarts with filter. Changed oil and checked with 5 quarts and dip stick reads full. Boat is on the trailer and is level. Should I put the 6th quart in?
cig1988 is offline
Old 07-05-2003 | 08:16 PM
cig1988's Avatar
I'm sure I have it all out. When I pulled the engines over the winter I installed the hose kit on the drain plug. Makes life alot easier. I guess I'll just order a dip stick and try that. Thanks for the input.
cig1988 is offline
Old 07-05-2003 | 09:38 PM
mopower's Avatar
Toxic FORMULA
I have the hose drain kits on mine , and they also leave some behind
Initial fill on mine was 12 qts. First change at 5 hours and 10 qts filled them , due to some left in pans , oil lines and cooler,
mopower is offline
Old 07-06-2003 | 05:43 AM
cig1988's Avatar
That would make sense. The more I thought of the dip stick being wrong it's odd that both of them would read the same. I checked the tubes also and all semms fine. As "too old" said, use dipstick to determine.
cig1988 is offline
kemiller
5
11-14-2006 09:07 AM
firecatgreen
2
05-29-2005 08:27 PM
bikinilover
3
11-18-2004 12:55 PM
BAD-HABIT
1
05-07-2004 04:29 AM
