Small Block Weight >
Small Block Weight
Small Block Weight
Old 07-07-2003 | 08:20 AM
JON242
Default Small Block Weight
About how much does a SBC weigh with aluminum intake and aluminum GIL manifolds? I want to be sure I'm not overloading my engine hoist.
Old 07-07-2003 | 11:50 PM
Bulldog's Avatar
A small block weighs about 500-550 lbs. I think on the lower side with an aluminum intake. Big blocks are about 600-650. This is with no exhaust or transmission on either. I would use a 1000 lbs minimum rated hoist , unless I did not care about what it landed on.
Bulldog is offline
Old 07-08-2003 | 05:02 AM
David's Avatar
I used to work in a place with a pallet sized scale (certified) to weigh product before shipment. I installed a small block motor there, and out of curiosity, I set it on the scale. Motor was 100% stock & complete as Mercruiser ships them. Weight was 880 lbs. Aluminum intake and exhaust should reduce some.
David is offline
Old 07-08-2003 | 11:46 PM
Bulldog's Avatar
David- was that with mounts, etc.? I think the weights I posted was for a basic complete engine with no accessories. I put a 302 Chevy in a 280Z a few years back and weighed each piece seperately. That was with no exhaust manifolds, etc. which I would imagine add few pounds. I think a big block was 120 lbs heavier, and aluminum heads subtracted 70 lbs from that. I still wish I would have stuffed my L-88 427 engine in the Z car- but I might not be here today, either!
It sounds like 1000 LBs is a safe number in any case.
Jon- Good Luck!
Ronnie
Bulldog is offline
Old 07-09-2003 | 04:44 AM
David's Avatar
Weight was 100% complete engine, ready to run, with exhaust manifolds, risers, starter, alt, flywheel, water pump, ps pump, hoses, belts, mounts, wire harness, etc. When I installed it, all I had to do was connect rubber exhaust hoses to risers, water hose from gimbal to thermo housing, plug electrical harness from boat in, hook up cables & fuel line, and of course, alignment. I also concur that a 1000# lift minimum is ok.
David is offline
handfulz28
10-15-2006 02:25 PM
DKerns
5
09-05-2006 01:40 PM
chriscraft240
4
08-28-2003 01:17 PM
pozguy
6
04-24-2003 06:38 PM
Da Patriot
44
11-24-2002 08:27 AM
