Bravo Oil leak -outside >
Old 07-07-2003 | 02:07 PM
Ran-Dom 32's Avatar
Default Bravo Oil leak -outside
Just got my lower back ( new prop shaft & vertical shaft) ran her all weekend - no problem - this morning I noticed drive oil coming out of the lower water intake holes - anyone have this problem -could it be the seal around the vertical shaft allowing oil to pass into the water passage???
Ran-Dom 32 is offline
Old 07-07-2003 | 02:32 PM
Mr Gadgets's Avatar
Charter Member #601
There are three seals between the lower and upper. Two big ones and one little one. The two big ones are different diameters, if I remember correctly.. better pull it and check. See if you have any water in the drive oil..
Good luck
Dick
Mr Gadgets is offline
Old 07-07-2003 | 05:11 PM
obnoxus's Avatar
Charter Member #1171
My guess is the little orange seal is missing
I want to live in a world where a chicken can cross the road and not have its motives questioned.
obnoxus is offline
Old 07-07-2003 | 07:45 PM
blue thunder's Avatar
If the boat is on a trailer try pressurizing the drive and spraying soapy water around the drive to look for bubbles. Kind of like an old bike intertube. Use an air compressor to put say 10-15psi into the lower unit through the lower drain plug. If you don't have a compressor, use a gear lube pump (with no lube) in the lower hole with about 20 strokes. Should pressurize the drive enough to find the leak. Make sure you do not run the boat any more until you ensure no water in the drive.
BT
blue thunder is offline
Old 07-08-2003 | 09:26 AM
Ran-Dom 32's Avatar
Pulled the lower & obnoxus you are correct - little orange seal for the oil passage is missing, thank for the help OSO
TROUBLE MAKER
Drives and Lower Units
26
07-04-2020 02:04 PM
mez
2
04-28-2007 10:45 PM
Dock Rat
12
05-11-2005 09:56 PM
HiPerf2000
4
06-17-2004 02:19 PM
RUSSSR1
12
03-17-2004 08:32 AM
